Identify Fordson Dexta and Super Dexta year model
sladetb
New User
I have a Ford 2000 but not sure what year or if its a Dexta or Super Dexta. Model number is a 957E 7005. On the rear end under the seat T4 3FZ25 ? hard to read. on driver side engine C or GKN1372 1G ? It has a single clutch hi/lo 3 foward gears.
The 957E prefix is Dexta or Super Dexta or could be a 2000 as the Dexta was sold in the US as a 2000. The numbers you need are cast
into the cast parts and will start either H22B or 3A22. These are just examples and not actual number. The longer cast-in numbers
are mould numbers and are the same on all tractors.
The serial number is stamped into the flange between engine and clutch on the fuel pump side. It will start either 957E, Dexta or
960E Super Dexta, 959E is Petrol Dexta. To confuse things they changed the serial number prefix in 1961 so you could also find
09A,B,C,or D depending on the year of production.
Taking a guess from your numbers 3FZ25 I would think you are mis-reading, if it is really 3F22 then it would be 1963, June 22nd.
(quoted from post at 01:34:05 01/11/16) The 957E prefix is Dexta or Super Dexta or could be a 2000 as the Dexta was sold in the US as a 2000. The numbers you need are cast
So I am guessing by the front end with the missing logo that I have a Super Dexta and there is an old 2000 sticker on there.
