Super Major Tire Size: Will These Fit?
Lute
New User
I have a Super Major that has been sitting for a while because I could not find a pair of used tires in the original 13.9 x 30 size.
Just found some Firestone 13.9 x 28's only a few miles from me.
Will the 28's fit with no issues?
Thanks
no if you are looking to put the tires on your original rims. If the new tires are on rims then Id say they would fit if the bolt patten is the same as
your tractor. It may sit lower if the overall diameter is smaller.
Figured it was too good to be true.
My Major has the original rims; six bolt pattern, 30".
The tires I found are in great shape but are on 8 bolt rims and 28".
And they are a giveaway.
Damit.
to get my tires to Florida wouldn't be cheap but if they would help I have some tires in louisiana. Not free but cheap.
The rear tires on your tractor should be 16.9x30, not 13.9!
Also, never heard of 13.9, should be 13.6!
16.9x30 should be fairly common and easy to locate used!
HTH, Dave
FYI, I shipped a pr of rear tires across the country a fews wks back for $100 thru Fastenal store to store. Can't beat that.
