65 Super Dexta 3000 fuel inj pump, self lubricating?
Ifixpower
New User
Just overhauled the engine and had the SIMMS/MINIMEC fuel inj pump overhauled in TN. Tag said no oil when I got the inj pump back. Does that mean that the pump is self lubricating?
If it requires engine oil, or special oil, how much does it need?
Diesel 3 cyl Perkins rated at 35hp...??...
Any advice, info, website, manual exerpts, etc is greatly appreciated :?:
As far as I know all Simms punps need their
own oil... Same oil as you run in the
engine, there should be a filler plug on
the top front of the pump (forward of the
injection lines), and a fill level plug
just rearward of the throttle linkage...
They don't take much oil, and it does need
change when you change the engine oil too.
