I've owned this 1960 Dexta for three years and am working on the charging system. The Generator was given a good rating by my local repair shop. The Dexta came without a regulator. I ordered and received one. It is the correct appearance, but it has four connections that are the Pin type. I do not have any of the original wiring, so I am going to wire it per the Dexta wiring diagram. I can not find any info about this type of regulator. It appears that the pin holes are about 0.200 inch in diameter and that the wires and pins would be held in by the metal plate that is labeled D, E, A, F. There is a phenolic plate and rubber gasket under the metal plate that would provide insulation.
A. Should I return this and get the screw terminal type?
B. Where can I get pins if I need them?
I'll put on the wire terminals that I need.
Many thanks, this is a great resource.
David
David
