A fellow brought me a Super Major to correct a fuel problem. I am no expert on anything let alone a Simms injection pump, so here goes.
The tractor will start and run reasonably well as long as the throttle is positioned about 1/2 open or more. If you run it at idle it will die after 5-10 minutes of running.
I have verified that the fuel supply is good as it sound like it is starving but why not at higher RPM? The original fuel transfer pump has been changed to an electric version and it seems to move fuel.I have ran the tractor with the return line disconnected to be sure there is no restrictions and with the filler cap off with no change there either. Customer has changed the fuel filter several times.
I would appreciate any input. Thanks
