Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Fordson Tractors Discussion Forum
Re: 1963 super major 3 point lift ????
Majorman
06-18-2014 09:03:23
Screen is underneath above the drawbar and held in with four bolts. It has the drain plug in the middle of it. Just infront of the screen are two bolts that have magnets on them so remove and clean these too.
You do not have to bleed the hydraulics.
If the hydraulics do not work, first check that you have the PTO in gear. If the lift does not work after standing the problem is most likely a stuck unload valve which will mean the hydraulics will have to be removed and serviced.
rastaman
07-02-2014 05:08:28
 Re: 1963 super major 3 point lift ???? in reply to Majorman, 06-18-2014 09:03:23
thanks Majorman. How does one go about servicing the hydraulics? I assume its in the section under the seat. Is it just a mater of taking apart and cleaning etc? If so are there any NO"s and cautions I should be aware of.
thanks for the help
