Anonymous-0
My Fordson Dexta's three point hitch hesitates to lift from a cold start but lifts after 30 sec - 1 min. It also when the lift lever is pulled all the way up lifts the 3point hitch to the point which I feel is to high, the lift arms are flexing from being pulled up to high. There is also a point at which the pump puts a load on the engine near the top end of the lift, I push the lever down slightly which causes the load on engine to go a way and also the flex out of the lift arms. I think it must be a setting or set screw that should be adjustable but I'm at a loss
Any suggestions? Thanks
