TractorLinks.com
Fordson Tractors Discussion Forum
Fuel dripping from pneumatic governor breather
Sleestak
05-01-2014 17:18:51
Hi I am new here and I hope I am not repeating a post. I just bought my first tractor . 1958 ford dexta 2000 diesel with Simms injector pump. I have fuel leaking from lift pump which I think is just a gasket. Does fuel lubricate the cam for lift pump? I also have fuel dripping from the governor breather port, I don't think this is supposed to do this. Any input would be greatly appreciated.
Thanks
Gary
Majorman
05-02-2014 00:34:46
 Re: Fuel dripping from pneumatic governor breather in reply to Sleestak, 05-01-2014 17:18:51
The lift pump cam is lubricated by diesel in the pump cam box. The lift pump can fail and overfill the pump with oil but there should be a breather tube with a curl in it on the cam box to allow excess diesel to fall on the ground. If you have diesel coming from the governor breather the pump is way overfull.
I would suspect you need a new lift pump.
Sleestak
05-02-2014 10:24:11
 Re: Fuel dripping from pneumatic governor breather in reply to Majorman, 05-02-2014 00:34:46
Thanks for quick reply! Ok so I figured out the previous owner plugged
The overflow with the curl was plugged by previous owner I unplugged it put a new governor diaphragm in and now I have fuel dripping from overflow tube constantly when running
So you think that excess fuel is getting past the lift pump diaphragm into the bottom of the Simms pump? I hope this is the case
Thanks
Gary
richardinnz
05-02-2014 16:59:47
 Re: Fuel dripping from pneumatic governor breather in reply to Sleestak, 05-02-2014 10:24:11
Most probably the lift pump leaking in, but the injector pump cam box is lubricated by oil not Diesel fuel.
Use the same grade oil as for the engine crankcase, it sould be changed when you do the engine oil, but not many people ever did!
Sleestak
05-02-2014 18:18:24
 Re: Fuel dripping from pneumatic governor breather in reply to richardinnz, 05-02-2014 16:59:47
Is this for sure on oil for injector pump? This is a 3 cylinder diesel with a Simms pump. I just want to make sure because I have seen any information stating that this is the case in my manual
I would appreciate any information I can get to confirm this
Thanks
I've got a new lift pump on the way
Gary
Majorman
05-02-2014 23:32:02
 Re: Fuel dripping from pneumatic governor breather in reply to Sleestak, 05-02-2014 18:18:24
No the diesel pump is not lubricated by oil on the pneumatic governor equipped pumps, it is lubricated by diesel that is bled down from the pumping elements.
On the mechanical governed pump on the later Dexta and Super Dexta, the Minimec, oil is used to lubricate the governor only, the pumping elements and cam box are still lubricated by diesel.
At least that was correct when I was a Simms trained engineer back in the day and working on these tractors.
Yes I would suspect you have a leaking lift pump diaphragm. That is the usual cause of excess diesel in the cam box.
Sleestak
05-03-2014 07:17:18
 Re: Fuel dripping from pneumatic governor breather in reply to Majorman, 05-02-2014 23:32:02
Thanks for your input and clearing this up for me Majorman!
Gary
