TractorLinks.com
Fordson Tractors Discussion Forum
Re: need help with 4wd front axel parts
budb4
04-24-2014 16:49:53
ote="WayneB"](reply to post at 06:38:26 04/24/14) [/quote] First of all I want to say thank you for all the info, replies, and pictures from all of you. I suspect the reason this is so difficult is because it was Ford UK's first attempt to build a front axel in house using other manufacturers' components, ( possibly Schindlers) . Soon after that Ford USA designed their own front axel which uses the reduction gears at the outer end of the axel for which a parts breakdown is availalbe and used on the first generation front ends in the USA and later UK models. Wayne, to answer your question, the 2 bearing caps you mentioned in the picture are the ones that I made which bolt to a 2 inch ring with 4 bolts and nuts and 2 identical bearing caps on the other end. That ring has grease ports and fittings that lube all bearings. The inner axel in the picture, upper right, is broken where the pin connects to the inner bearing housing. The inner bearing housing which is broken in half is in the center right of the picture.Thanks, Wayne, for the additions resources to locate the parts. Bud
