TractorLinks.com
Fordson Tractors Discussion Forum
Re: Dexta steering gearbox shim gasket
WayneB
03-23-2014 09:20:45
Two more points:
1. Shims are only on left housing. Right housing does not need pulled. Seals may be replaced without pulling housings. Pull left housing and remove shims till wheel is tight, but turns well. Clean crud from bottom before re-assembly, there normally is crud. (shim removal) This is only after rebuild of top shaft, or it it tight.
2. Dexta wheel wobble most of the time is caused from worn tie-rod ends. **with rebuilt steering gers, new tie rod, and spindle bearings, and with a steering wheel spinner knob, my Dextas steer with one hand.
