i discovered a broken control valve spring in the lift cylinder on my 1959 Fordson Dexta after disassembling to troubleshoot no lift on the rear arms. does anyone know the specs (length/diameter/spring rate) for the spring or know where i can buy one? also replacing o-rings on pump, ram, and diverter valve and replacing oil filter element. case was full of water and filthy oil before disassembly. rear arms worked when i first got the tractor but stopped functioning after a couple hours of work. when i saw how dirty and full of water the case was i figured i might as well pull the cover and give it a good cleaning, do an o-ring replacement, and check for damaged parts. any help with specs or locating a spring would be greatly appreciated.
