fordson hydrylic hose adapter
jofus
New User
i have a 63 fordson that has a backhoe attachment and i am looking for an adapter that goes in the hydrylic valve that will go to a standard adapter. looked online and can only find air conditioning ends. anybody know where i can get the kind of fittings i am looking for. also....i cant find the serial number on it. anybody know where they mounted it?
Hi
Tractor serial number will be engine number Stamped on a pad on the block under number one fuel injector on front right side of block. Hopefully it still has the right motor fitted as if not you got to decode casting numbers on a few components to verify age.
I guess the back hoe and loader would have it's own serial number tags fixed on.
For hydraulic adapters usually any tractor and machinery dealer locally or a bearing and hydraulic supply company carries them , You will need to tell them what the thread sizes and type are, or take the parts you need to join together to them. They will then either have the part on the shelf or get it for you. there are hundreds of different adapters out there for hydraulics.
Regards Robert
where can i find the original style gauges for 1963 fordson super major...diesel. one gauge has temp, gen, and oil. the other gauge is tach, hour meter, and speed (mph). tried speedographrichfield and they dont have. thanks
