TractorLinks.com
Fordson Tractors Discussion Forum
Re: Fordson Super Major starts but runs slow.
mike farmer
12-24-2013 00:55:26
Hi. You are probably all advised out on this one but I've had a little think to see if theres any thing else to suggest. Assuming you have anormal simms pump, when you press the cold start does the rack actually move? you'll need to take the side panel off to check. If the air breather has moisture in it it will freeze up and not allow the damper to move properly. You could try wrapping a cloth around the diaphram and pouring hot water over it. The cloth will retain the heat and get rid of any ice. You have probably already tried removing the air intake pipe and holding a twist of burning newspaper over the intake whilst you use the starter so it sucks hot air into the engine, but its worth a mention. (thats my favourite). Is the butterfly valve in the intake working correctly. If you've already been down these lines then sorry to bother you. Have a nice season. Mike
