TractorLinks.com
Fordson Tractors Discussion Forum
Re: Transmission Output Shaft different
WayneB
10-15-2013 06:14:28
Majorman, I have decided to convert my 59 Dexta to a Super Dexta. Either way, I need to take the slop out of my Hyd top linkages, replace bearing & seals on my axles and brake pads. The only problem with the parts super rear end is the PTO (looked like it may have jump out of gear), and I will swap parts from my 59 or replace as necessary. I can't sell the tractor, as it is my wife's, and she is sentimental, but for me to make it a super would be fine. My part tractor is 100% complete, so I will need for nothing in the swaps. I rebuilt my block to 152 and it is the best running Dexta engine I have ever seen; a real keeper. This fits, the parts super block will give me an extra, and I can sell or scrap the rest. I will have a lot of parts to sell, and one bay to park a running tractor. This will make 4 Super Dexta tractors on my farm. One set of spares. THANKS FOR THE ADVICE.
Wayne
WayneB
10-20-2013 11:26:45
 Re: Transmission Output Shaft different in reply to WayneB, 10-15-2013 06:14:28
UPDATE. Both tractors have transmision and rear ends RE-assembled. The parts tractor is ready to pull out of the shop fully assembled with my old rear end. Taking my time with the Dexta to Super Dexta conversion. I was pleasantly surprised when I pulled the Super Dexta part tracor apart. Very clean, and clearly had not been pulled apart. The top cover had been pulled but nothing else. I swapped the PTO pawl and assembly of tranny to rear end was so easy. Compared to my Ford 4000, this job was simple and easy to do. On scale of 1-10, with ten difficulty near impossible, this jobs was a 2. On the used to be Dexta, but now is a super Dexta, have married the engine back to the tranny, and will get her running. When I assembled the tranny to the rear end, I put the coupler shaft on the rear end, pulled it back until it was almost off the spline, and reached in and started it on the tranny spline. I went together so easy. I had fabricated a gasket out G-paper, and had all the bolts in holding gasket on. Too easy.
Don't think I will mount the fuel tank, but use a small tank to run it. Will not fully assemble, will paint before assembly. Prior to that, will do axle seals & bearings and re-line brakes. Then it get washed and scrubed for painting.
It will be the paint that makes this Super Dexta better than my others for the wife.....
