Philip Harold-Barry
New User
Hi,
You could be correct as the lift does get stuck in the upward position for a few minutes after.
Will try as you suggested.
Thank you,
Another problem that could be related, when using external hydraulics to lift a post driver the Dexta will only operate when the tractor is idling. If I increase engine revs and try to operate post driver a loud click is heard from top of gearbox/hyd and hyd fail to operate until the control valve into returned to neutral.
Thank you,
