TractorLinks.com
Fordson Tractors Discussion Forum
Re: Dexta hydraulic relief / check valveproblems
Majorman
09-25-2013 00:59:48
It may be that your lift arms are creeping up and the linkage is putting the control valve into neutral. This is normal and may be overcome by moving the control lever beyond the top stop on the quadrant or by fixing the linkage in a slightly lowered position with a chain.
Philip Harold-Barry
10-01-2013 04:44:25
 Re: Dexta hydraulic relief / check valveproblems in reply to Majorman, 09-25-2013 00:59:48
Hi,
You could be correct as the lift does get stuck in the upward position for a few minutes after.
Will try as you suggested.
Thank you,
Another problem that could be related, when using external hydraulics to lift a post driver the Dexta will only operate when the tractor is idling. If I increase engine revs and try to operate post driver a loud click is heard from top of gearbox/hyd and hyd fail to operate until the control valve into returned to neutral.
