TractorLinks.com
Fordson Tractors Discussion Forum
Re: Another unstuck Dexta
WayneB
06-16-2013 13:56:03
I worked on it some more today. Absolutely, the problem is the valve at the tank. Draining the tank to replace that next weekend. I have a couple of new ones spare. The fuel wasn't clean anwway, so I have a couple or three gallons to start fires where I'm clearing.
Also fabricating optima battery mounts. Next will come "00" battery cables. I find the original cable lacking once you put a key seleniod starter on and with optimas, you never have battery corrosion again. The adventure continues.....
Wayne
WayneB
06-17-2013 11:14:07
 Re: Another unstuck Dexta in reply to WayneB, 06-16-2013 13:56:03
Worked on the old girl till after dark. New primer cut-off valve installed and system bled out. I have a leak on the line to primer and will need a new ferrule.
The strainer screen did its job on the big stuff and the filter on the small. With new fuel I was getting a good clean flow.
Next weekend will pull start her for first run-out.
Wayne
