Yesterday's Tractor Co.
Shop Now View Cart
Fordson Tractors Discussion Forum
Re: Another unstuck Dexta
06-15-2013 17:34:45
She runs. This one was a wild stubborn mustang to get running. Injector pump rack was stuck in the no fuel position, and took a little penetrant to get working again. When I did get it running, it was smooth but repeatedly would run then run out of fuel. While I have good flow, I lack I lack volume. New filter and tank shut of valve will be next targets. No leaks. I can work with this.
06-16-2013 13:56:03
 Re: Another unstuck Dexta in reply to WayneB, 06-15-2013 17:34:45
I worked on it some more today. Absolutely, the problem is the valve at the tank. Draining the tank to replace that next weekend. I have a couple of new ones spare. The fuel wasn't clean anwway, so I have a couple or three gallons to start fires where I'm clearing.
Also fabricating optima battery mounts. Next will come "00" battery cables. I find the original cable lacking once you put a key seleniod starter on and with optimas, you never have battery corrosion again. The adventure continues.....
06-17-2013 11:14:07
 Re: Another unstuck Dexta in reply to WayneB, 06-16-2013 13:56:03
Worked on the old girl till after dark. New primer cut-off valve installed and system bled out. I have a leak on the line to primer and will need a new ferrule.
The strainer screen did its job on the big stuff and the filter on the small. With new fuel I was getting a good clean flow.
Next weekend will pull start her for first run-out.
