TractorLinks.com
Fordson Tractors Discussion Forum
Re: fordson major no oil pressure
ron d w
06-07-2013 14:59:07
With a regular 3/8 drill on shaft it will pump lots. As soon as you put all covers on it won"t.I took all apart and tightened everything. put all back together and same problem. It will not build pressure.Do not understand why it will throw a 1/2 stream of oil out the filter oulet in block across the room with an elecrtic drill but will not pump when you put everything back together with motor running. Will not even get oil to filter. Have tried priming pump but as soon as motor stops quits pumping again. Lots of oil and all usual things have been checked
r on d w
08-16-2013 12:59:08
 Re: fordson major no oil pressure in reply to ron d w, 06-07-2013 14:59:07
Still no luck. Decided to get new pump.engine ser # 1537800. Now I need a new auxiliary drive shaft E96-CP9 to fit newer pumps. Ford OEM part. No luck. from ser # 1599502 all have this newer drive shaft for pump. Any ideas were to get. Also 3 bolt camshaft not available. Can I update to newer one bolt and what else do I need??
r on d w
06-08-2013 20:20:16
i took oil pan off again today. retightened all. tried with drill on injection pump shaft, pumped right away, put timing gears,covers,oil pan and tractor back together. took all day, started up and no oil at all. primed from gauge and filter. no luck.have filter housing off and just oil i put in came out and quit.I know pump is turning. I never disconnected from when i used drill.Is there a way to see if relief is dumping under very low pressure. Original mechanics who put together got pump off ebay.
