Yesterday's Tractor Co.
Shop Now View Cart
Fordson Tractors Discussion Forum
Re: 220 Dagenham Ford Industrial Diesel
Robert Major
05-22-2013 21:27:29
Hi it is possible to buy a new crank on ebay for that motor for about $350 ish plus shipping. I think A&I parts do one as well but it"s more like $750. A&I parts Do the oil pump to that"s about $150, plus your re build kit. It"s cheaper for me to buy new cranks than grind old ones now here in Canada.
The Dover and Dorset bell housing pattern should be the same if yours looks more like a perfect circle rather than more egg shaped at the bottom, like the old cast iron tractor pans are. Some truck aplications also had a slant oil pan to, you need an upright pan im guessing for your job . The motor mountings might need work, and the water pump is off center on both the Dover and Dorsets I have. so you might have to work on the fan shroud,fan and the water outlet on the rad bottom, is the opposite side with mine too. The oil pump was moved from the front right on your engine to not quite the back right on those newer ones too. so if the pan on yours is special for under clearance you can"t swap them over either. you might have a hard time finding a newer 4 cyl around they don"t seem to be that common in North america. both my 4's came direct from the uk. my 6cyl turbo's came from New Holland TR 70 combines in Canada.
There are more 220's and parts around as diesel versions are in the major series tractors with some modifications along the way. industrial"s had some head/intake and injection equipment changes different to tractors to though. my advice would be get the parts and do yours it might be quicker to fix what you got, than end up with a whole load of headaches trying to find and fit the newer engine. Then find ya back in a mess when that"s no better than what you got now. I"ve messed with a few of these newer motors over the years putting 4 and 6 cyls in majors. it"s not an easy fun swap. If you have more questions I'll try and help just ask.
Regards Robert
05-23-2013 05:49:10
 Re: 220 Dagenham Ford Industrial Diesel in reply to Robert Major, 05-22-2013 21:27:29
