Dexta starter search + ground.
I found a starter from Reliable Aftermarket Parts in Michigan for $135. I bought it and after I received it I thought I'd better check if it was possitive or negative ground. I was told it was negative ground. How difficult would it be to change my Dexta to negative ground. Would it mess up my voltage regulator or generator?
Thanks,
Jack
Unless it's some weird starter, it doesn't matter, it will work + or -. A typical starter turns the same way with either.
