Timing gear/camshaft thrust washer
I am looking for a timing gear and camshaft thrust washer for my Power Major. I believe it is a 57. The part number I have for the timing gear is EIADKN63C6-B. I don't have a part number for the thrust washer but it is a horseshoe shaped washer that goes on the end of the camshaft. Mine was in several pieces when we took the motor apart. Any help would be greatly appreciated. It appears both parts I'm in need of are salvage parts.
Thanks,
Lance
Check www.agrilineproducts.com/partscatalogue/major.html in the UK, or these guys www.importtractorparts.net/fordson.html in North America.
You might try Fordsontractorpages.NL/manuals to find the part number.
Probably same part used on Dexta, Super or Major
Import tractor parts was able to help with the timing gear but not the camshaft thrust washer. Agriline products doesn't have the washer listed in their parts book but maybe I will try and call them.
Thanks for the help!!
I checked with my local machine shop and they could make it but to the tune of $250 or more. The thrust washer is 4 points shy of being file hard steel. Not sure it needs to be that hard but the original was.
Hi. Might be worth try Keith at www.cotswoldvintagetractors.com I know they carry a certain amount of Fordson major salvage parts. suggest you just go to their site and take it from there. Generally helpful. Mike
Hi there I am looking urgently for a horseshoe shaped camshaft thrust washer for what I believe is a 55-ish Fordson major, do you still have the part? If we could establish it is the correct piece I would gladly pay for shipping and the part.
