Anonymous-0
Hello, i found a discussion thread on hydraulic fittings for a Ford 713 backhoe dated 2004. Would anyone be of assistance on request for information to find a standard or sae fitting to fabricate hydraulic hoses for obsolete fittings. The post i found was by a Scott in pa
08-07-2004 18:03:29
24.159.2.105
Re: ford major backhoe in reply to derek, 06-23-2004 21:30:15
derek,
who built the backhoe attachment? Ford or sherman are the two i have come across. I own a 61 supermajor with a ford loader and hoe. The factory fard hose fittings are available from ford/new holland but are about $35 each. I had a guy look at mine and he discovered that the valves and cylinders are double seated. They will accept standard sae fittings. I replace every hose except 2 on mine with the standard fittings and haven't had a problem in the 1 1/2yr since. If you want a picture of the new fitting email me and i'll send it to you. good luck
08-07-2004 18:03:29
24.159.2.105
derek,
