Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Fordson Tractors Discussion Forum
Re: Fordson
cdmn
01-08-2013 12:09:21
Pretty simple tractor. Needs clean carburetor, good spark, antifreeze, lots of oil, and a strong cranker. See if it has a belt pulley on it. Might be best way to get it running. Do not attempt to tow in gear. The worm gears in rear end can't be driven that way without damage. You'll need a 6volt battery to apply voltage to the coil box for starting. A dry cell battery will do. Timer could be greasy and not functioning properly. You should hear the coils buzzing at each stroke.
mikeintn
01-08-2013 15:01:50
 Re: Fordson in reply to cdmn, 01-08-2013 12:09:21
I went and looked at it, it looks like its a 1920 going by serial #, I thought it should have a coil box, but it had a mag. on the bottom right side of engine, it does have a belt pulley, it wasnt running and I didnt try to start it, I thought it was alittle over priced.
cdmn
01-09-2013 19:40:47
 Re: Fordson in reply to mikeintn, 01-08-2013 15:01:50
Sounds like it is an Irish or English model. They used an external magneto
Copyright © 1997-2015 Yesterday's Tractor Co.
