Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Fordson Tractors Discussion Forum
Topic: Pics-What Do You Think About This English Fordson
[Return to Forum]
1206SWMO
12-20-2012 09:16:46
184.63.199.33
Its an older restoration but the motor is stuck..Couldnt read the serial # but I assume its mid 1930's..It has pto and a belt pulley..11 x 28 rear tires will hold air but fronts are shot..Radiator is perfect,block seems OK..Asking $1200 but $1000 would probably buy it..
[Reply]   [No Email]
cdmn
12-20-2012 17:02:34
66.228.249.73
 Re: Pics-What Do You Think About This English Fordson in reply to 1206SWMO, 12-20-2012 09:16:46
The price isn't bad. It's about as nice as any I've found. The rear wheels look like they were originally steel lug, cut-off and rubber tire rims welded on. A couple companies made 24 inch rear wheels, but most farmers cut off the originals. I can't tell about your front wheels. The round spoke is a replacement wheel of some sort. If the rear tires hold air, that might be good enuf for parades. The fronts should be replaced with tractor-style tires.
The tractor looks very complete and well-preserved. You can tell how much use it had by whether the draw-pin hole is worn, or other signs of wear. Many may have ended their careers as belt-tractors and not used for field work at all.
It would have been painted the dark Fordson blue with Orange wheels and hi-lights.
[Reply]  [No Email]
cdmn
12-20-2012 16:42:50
66.228.249.73
It's a 1937 or slightly older. The air cleaner inlet on the steering column went away for 1938.
The serial number is on the opposite side of your picture and closer to the front. If you are patient and use good solvents or lube, you can get the engine loose. It would be easier if they had a starter ring gear to put some force on it. Do not try to pull it in gear and pop the clutch. That will tear out the worm gear rear ends. Attached is a view of mine
[Reply]  [No Email]
Butch Howe
12-20-2012 11:13:52
67.240.127.219
looks complete. rear wheels are earlier cutoffs. Zenith gas carb. It's 1932-36. See how much water is in the pan before you buy it.
Value is hard to figure. I hope it can be saved from the scrap guy. If it can be freed up it would be a good one as you don't have to hunt down parts.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
