major with roadless
hi mike just picked up a major with a roadless front assist it has manual in the casting on the front axle i need to know were the #s are to identify what i have and year it was built for now thanks mike
Hi. I dont know anything about roadless so for that you would be better speaking to KFD68. If you only want tractor #No's. The engine No is on a machined flat on the deisel pump side at the front of the engine just back from the water pump and just below the head gasket level. It will (should) also be on a plate on the battery side of the firewall. If its a very old model it could be stamped on the casting underneath the battery carrier. If the No's are different it probably means a change of engine. Has your deisel pump got a vacuum governor.
Mike
hi kfd68 as you read the post to mikefarmer trying to find out info on exactly what ive got so any help would be great thanks tim
Hi:
I am trying to turn my 1963 Fordson Super Major into a roadless.
Was lucky to get the transfer box, but not the front diff.
Just got two front diffs from two CMP military truck, seems like one diff was from a 3 ton and the other from a 5 ton, Not sure what the ratios are on the diffs.
I have searched but have not been able to find a diff from a GMC WWII truck like what Roadless Traction originally used.
Any help or advice would be appreiated.
I am in Halifax, Nova Scotia, Canada.
Kenneth Armour
In answer to the questions about Roadless 4wd tractors, I start a new thread to explain the history behind them.
Hello Kenneth , I have a partial Roadless kit for a Major , just a Transfer Case and Front axle housing no mounting brackets or steering parts but know where there is at least two more Roadless's that are complete but NOT FOR SALE for pictures and specs. to Fabricate parts , plus know where there is WW2 GMC axle parts also . Thanks Tony Jacobs
