Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Fordson Tractors Discussion Forum
Re: ring and pinion contact pattern
mechanicfred
08-28-2012 07:54:50
The pinion depth has to be right and then you move the ring gear carrier left or right until desired gear contact pattern is obtained.This is normally done with shims but I have seen screw type adjustments also.I use Prussian Blue marking compound and have some drag on the gears to get a good look at the gear pattern.
kborsch
08-28-2012 18:45:24
 Re: ring and pinion contact pattern in reply to mechanicfred, 08-28-2012 07:54:50
Hi Fred,
Let me roll that around in my mind for a couple days thinking about the compound angles contacting each other and see if I can envision the solution you suggest. Thanks for the help!
Kerry
