TractorLinks.com
Fordson Tractors Discussion Forum
Re: Fordson M ajor 4 cylinder diesel around 1960
tiresntracks
07-20-2012 16:23:29
Robert, I just re-read your post. The timing cant be 180 out if the clamp bolt is on the bottom. It can be a few degrees off because of the slots in the coupler, but not 180. The position of that clamp bolt is just an easy way to tell what position the cam is in. If the clamp bolt is on the bottom, the cam has both valves closed on no. 1 cylinder and its on the compression stroke. If the clamp bolt is on the top the cam has the exhaust valve open and its on the exhaust stroke.
Robert major
07-20-2012 21:17:54
 Re: Fordson M ajor 4 cylinder diesel around 1960 in reply to tiresntracks, 07-20-2012 16:23:29
My point is the fuel pump can be half a turn out on the pegs if the guy doesnt have the marks on the pump and coupling lined up. the two marks on the pump should be lined up at the front as you look at the pump on the motor. if he has the coupling timing mark at the back it will be 180 degrees out. motor timed on no 1 cyl acording to fly wheel and pump could be set to inject no 3 cylinder if my thinking is correct. the coupling will fit together in 2 places is what im trying to say.
Regards Robert
tiresntracks
07-20-2012 21:34:25
 Re: Fordson M ajor 4 cylinder diesel around 1960 in reply to Robert major, 07-20-2012 21:17:54
I see what you're saying. If you can't see the marks on the coupler and the pump, you could still be 180 out with the pinch bolt on the bottom.
I think there's a reason that we're mechanics and not teachers!
Robert major
07-20-2012 22:14:11
 Re: Fordson M ajor 4 cylinder diesel around 1960 in reply to tiresntracks, 07-20-2012 21:34:25
no problem I have many majors here in my collection and worked on or sold many more so really didnt want to argue with ya about this :).
I find its easier to go in the shop and do it than try explaining it to a guy on here and ya cant see what he's working with.
I work on so much stuff that the monkeys have played with before the new owner tries to get it right and it makes hard work of it, especialy when it had one problem messed with and caused 49 more problems and still didnt fix the original fault and no body knows what that was when i get to look at it :( lol.
hope ya Have a good one:)
regards Robert
