| Fordson Tractors Discussion Forum |
Topic: Re: Oil Sump (pan) Need Super Major
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| mike farmer
07-15-2012 03:30:45
82.6.32.224
Before going to any great expense try grinding a shallow groove inside and out then fill it with JB weld. Theres no real pressure in there and youve got nothing to lose. Cleaning up where the seal goes will be less difficult the a metal weld. Mike |
| rickne
07-16-2012 10:20:28
198.180.0.254
Re: Oil Sump (pan) Need Super Major in reply to mike farmer, 07-15-2012 03:30:45
| Quoting Removed, click Modern View to see
Thanks Mike,
That was my first thought BUT, I really only want to remove and install that beast of a sump one time!
The replacement should be here Tuesday and if the weather holds, I will get it back on.
It has been like in the 100's here and it is crippeling us northern plains folk! |
| rickne
07-22-2012 07:25:55
68.99.16.252
Re: Oil Sump (pan) Need Super Major in reply to rickne, 07-16-2012 10:20:28
Well the attempt by the welding shop failed. I located a used one, it came and looks fine.
I had to shim my radius arm as my old oil pan had a 1" hole to match the radius arm, the new one has a 3/4" hole. No big deal, got a top link bushing and it was a little small so built it up with brass rod, inserted it into radius arm hole backing it up with some locktite press fit green.
All fits together well.
I have the pan cleaned up and painted and the block sealing surface ready.
I did quit a bit of leveling work on the oil pan sealing surface, guess over the years and perhaps form the factory it was not real true.
Now to line up the help (someone than can bench press more than me!).
I am going to clean and paint the engine while it is this far torn down so wont put the freshly painted pan on until the front half it cleaned up and painted.
Still reaching 100's around here so things are going slow!
Rick H... |
| rickne
08-01-2012 14:58:27
68.99.16.252
Re: Oil Sump (pan) Need Super Major in reply to rickne, 07-22-2012 07:25:55
Well got the oil pan put on. Used floor jack with transmission adapter and one other person to work the jack.
Here is a tip, if you remove and reinstall the timing cover, make sure you do not put to long of a bolt through the front plate on either side!!!!!
That little miss hap cost me an hour of twisting turning and sweating in the terrible temps we been having. Glad I did not force anything!
Rick H... |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
