| Fordson Tractors Discussion Forum |
Topic: fordson super major needs repair.
[Return to Forum]
| Author |
[Modern View]
| M.Given
06-30-2012 14:25:04
24.115.178.168
I have a 63 super major which I haven't been able to get running.I had it into a Kabota dealership and they told me they couldn't get it running.I brought it home bled the system several times and was able to get it running.Unfortunetly it shut down and haven't been able to get it started since.I live around Scranton PA.Is their anyone around me that can get this up and running for me? |
[Reply] [No Email] | |
| Majorman
07-01-2012 02:41:30
86.132.180.77
Re: fordson super major needs repair. in reply to M.Given, 06-30-2012 14:25:04
| | You could also take the plate, held on by two bolts, off the side of the injection pump. Be sure to keep it extra clean as you do it. With a screwdriver, make sure the slide (rack) moves freely against a spring backwards and forwards. It can stick and give you these problems sometimes. Use lots of WD40 to make sure it is free. Also check that the small button in the pivot of the stop control is out. Grip it with a pair of pliers and pull. Push it in and out again with lots of WD40. You should set the throttle half way, the button should stay in then fly out when the engine starts or the stop is pulled. As said in other posts, make sure all your filters are clean, there is one in the fuel tap that can catch you out. |
| curtsat15
06-30-2012 20:30:48
206.45.233.57
| How old is the fuel? Diesel will keep for a couple years in a closed tank with no foreign material in it. Have you changed the fuel filter? Checked the tank for rust, crud, etc.? Checked the fuel shutoff petcock for blockage? Checked the lines themselves for blockage? Are the injector lines sealing to the pump and injectors? Does the injector pump work? An electric fuel pump will only mask the real problem, not fix it. These reliable old mechanical diesels were designed for gravity feed fuel flow, and work extremely well when properly maintained. Check the whole system front to back before you start adding stuff that was never meant to be there. Hope this gives you some idea of what to look for. Sorry if it sounds like a rant, but there it is. |
| jdv
06-30-2012 15:51:51
67.209.221.197
| if its just the fuel your having trouble with you might try putting an electric fuel pump on it 60 bucks at most auto stores |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
