Charlie T. in VA
New User
OK, I need some more help with the Fordson Dexta. I replaced the manual fuel pmp and the diaphram on the back of the injection pump, (reccomended by Wayne B) tractor ran like new for a while. Was bushhogging and started to loose power, no throttle response just kind of idling along, limpped back to the barn. Check the fuel tank, sedimemt, cleaned the tank, replaced the fuel filter, new dsl fuel. Pull started the tractor (I ran the battery down trying to start the tractor). Again tractor running like a champ!!!, went to do some bushhogging and lost power again. checked everything all tight, no air leaks, can not figure out what's up. Was checking the air intake, has very little suction?? Could this be the problem??? What do I do or check? Any and all help appreciated!!!! Thanks Charlie
