Wheel wobble
Hi. I've just picked up on the posts on this subject. I was looking at a Major quite recently that once had the same problem. The owner had cured it by getting two strips of lead approx 6" long, 1" wide and about 1/8th" thick and stuck one on each rim opposite the air valve. I cant say whether it worked or not by the guy absolutely swore by it. Gotta be worth a try. I would be interested in the result if anyone out there gives it a go. Mike
I'd say King Pins & Bushes are worn - typical wear - easy & cheap to cure now spares are readily available.
Not so, I have replaced all the bushes and pins in the front end and it still wobbles, if I am on the road and slow down, it rights itself. I think it might be in the steering box. I am not overly concerned because it is only on the road on rare occasions.
Mostly use underdrive top in the paddock, minus the wobble.
