Fordson Major Diesel Hydraulic
I have 1963 FSM.
It has a valve untop the hydraulic cover that allows me to use the front blade or back arms.
I do not have the quick connects on mine, but would assume if you have the valve like what I have would be simple to plumb into the hose that feed the front rams.
In the alternative could also plumb into the pipe that you use for dumping the trailers.
Kenneth Armour
