Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: not getting fuel
Jack Mayers
05-17-2012 19:36:26
Joe,
If it's like my 57 there is a 1/2" bolt on the front side of the injector pump, it's the bleed screw. Loosen it and hand pump the fuel pump with the little handle on the underside of the glass bowl. You should feel some resistance when you pump it. After fuel comes out of the bleed screw close it. If it still won't start loosen the fittings at the injectors and turn it over until you see fuel. Hope that helps. Also if your getting fuel as far as the bleed screw and no farther it may be the injector pump itself.
This post was edited by Jack Mayers at 19:38:17 05/17/12.
