| Fordson Tractors Discussion Forum |
Topic: not getting fuel
[Return to Forum]
| Author |
[Modern View]
| Joe Sixpack
05-17-2012 16:38:53
67.54.142.160
I have a '53 Major Diesel that has been sitting for about 3 years. I cannot get it going. I believe I am bleeding the system correctly but am unable to get any fuel out of the top of the injector lines or out of the injectors. Everything seems fine up until that point. What am I doing wrong or is wrong with it? |
| Robert major
05-18-2012 21:06:21
216.130.71.254
Re: not getting fuel in reply to Joe Sixpack, 05-17-2012 16:38:53
| Hi If it is bled through correctly and still no fuel at the high pressure lines. clean the injector pump real good. take the plate off the side ( you do not want grit dirt or grass /straw blowing in the pump). pull the stop control rod and see if the rod that runs along the bottom of the housing moves, if not the stop control is stuck it should move back and forward free if not try lubing it with wd 40 or similar and try to free it be carefull as things will break easy in there do not move the adjusting arms as this will throw your pump out of calibration. if it is not stuck there turn the motor and see if the 4 pump elements move up and down. they should go about 1/2 to 3/4" from memory. if they do not move it is probably time to go looking for a rebuild or good used pump. I have messed with them and freed them. I have been doing it for years. I dont know your technical level and dont want you to go in with a hammer and wreck your pump completely . see how you get on and let us know. Regards Robert |
| Joe Sixpack
05-19-2012 05:46:38
67.54.142.160
Re: not getting fuel in reply to Robert major, 05-18-2012 21:06:21
| I will have to try that. Removed the lines and did not get any fuel out of the injector lines at the head or at the pump when turning over the engine. |
| curtsat15
05-18-2012 02:41:09
206.45.231.172
| Sounds like you're getting fuel to the pump but not the injectors? Disconnect the lines from the injectors and crank the engine. If you get fuel through all the lines, GREAT! If none or only some, I would suspect the lines are plugged. Disconnect them and clean them thoroughly. Put them back on IN THE SAME ORDER THEY CAME OFF. If still no fuel, it is time to look into your pump, and that is beyond my knowledge. Hope this helps! |
| Jack Mayers
05-17-2012 19:36:26
184.75.123.14
Re: not getting fuel in reply to scottd, 05-17-2012 16:38:53
| Joe,
If it's like my 57 there is a 1/2" bolt on the front side of the injector pump, it's the bleed screw. Loosen it and hand pump the fuel pump with the little handle on the underside of the glass bowl. You should feel some resistance when you pump it. After fuel comes out of the bleed screw close it. If it still won't start loosen the fittings at the injectors and turn it over until you see fuel. Hope that helps. Also if your getting fuel as far as the bleed screw and no farther it may be the injector pump itself.
This post was edited by Jack Mayers at 19:38:17 05/17/12. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
