TractorLinks.com
Fordson Tractors Discussion Forum
Re: fordson
Super Trucker
04-30-2012 17:14:27
Your Fordson has a worm drive to transfer the power to the pinions. This problem is not a problem but very normal. However you can't pull start it either. If your tired of cranking just belt it up to another tractor. Is this a Row Crop/All Around or a F/N model?
Al Seimet
05-01-2012 07:57:29
 Re: fordson in reply to Super Trucker, 04-30-2012 17:14:27
I do not know the type of fordson. It was made in England not Ireland. You can't pull it as the tires with weight on them will not role because as stated before if the rt is turns forward the lt roles the opposite direction. Also you can crank the engine over even if the the tractor is in gear. Its like the clutch is depressed so there is no transfer of of power from the cranking to the gear box..
cdmn
05-06-2012 19:58:12
 Re: fordson in reply to Al Seimet, 05-01-2012 07:57:29
Don't try to tow this tractor. You are risking breaking the worm gear set if it doesn't turn very freely. You should properly remove the worm from bottom bearing of rearend.
If it was made in England, it would be 1933 or later. Only a few were built in 1933 or 34 because of the worldwide depression.
