Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Fordson Tractors Discussion Forum
Topic: fordson
[Return to Forum]
Al Aeimet
04-30-2012 14:00:25
76.76.33.183
I have a 1930 fordson tractor with the following problem. The engine will role over with the tractor in gear. The clutch and brake are on one peddle. With the weight off the rear tires and in gear you can role the rt tire to the front and the left side will role in reverse with out the engine turning over. Could the clutch be engaged or stuck letting the engine to role sepertly? If so will I need to split the tractor to fix the problem or is there an easier way to fix the problem? Or what might the problem be and how do I fix it?
[Reply]   [No Email]
Super Trucker
04-30-2012 17:14:27
99.29.199.178
 Re: fordson in reply to Al Aeimet, 04-30-2012 14:00:25
Your Fordson has a worm drive to transfer the power to the pinions. This problem is not a problem but very normal. However you can't pull start it either. If your tired of cranking just belt it up to another tractor. Is this a Row Crop/All Around or a F/N model?
[Reply]  [No Email]
Al Seimet
05-01-2012 07:57:29
76.76.33.183
 Re: fordson in reply to Super Trucker, 04-30-2012 17:14:27
I do not know the type of fordson. It was made in England not Ireland. You can't pull it as the tires with weight on them will not role because as stated before if the rt is turns forward the lt roles the opposite direction. Also you can crank the engine over even if the the tractor is in gear. Its like the clutch is depressed so there is no transfer of of power from the cranking to the gear box..
[Reply]  [No Email]
cdmn
05-06-2012 19:58:12
66.228.249.73
 Re: fordson in reply to Al Seimet, 05-01-2012 07:57:29
Don't try to tow this tractor. You are risking breaking the worm gear set if it doesn't turn very freely. You should properly remove the worm from bottom bearing of rearend.
If it was made in England, it would be 1933 or later. Only a few were built in 1933 or 34 because of the worldwide depression.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
