| Author |
[Modern View]
| C Holt
04-11-2012 20:34:58
64.231.119.65
Attempting to help my father locate an engine block to fix his Ford 5000 Super Major. I think it is a 1963 with the 4 cyl. diesel. I guess the original block cracked after engine seized. Suspect faulty oil pump. It sounds like all the other parts are available but the block is more difficult to find. Any leads or suggestions?Thanks, |
| Dave Panning
05-09-2012 06:20:22
97.73.64.150
Re: Searching for Super Major Block or Parts Tractor in reply to C Holt, 04-11-2012 20:34:58
| Ford made lots of changes on these blocks over the years. I have one from a 1963 model or so. Mine is cast# E1ADDN6015E. Do you have a cast# on yours? Give me a call or email me. Thanks, Dave Panning Bros Tractor Parts Gibbon, MN 800-635-0993 |
| Lamoca4
05-04-2012 13:01:13
70.248.29.2
| Amatt NWOH would you be willing to part out you Fuel Filter Assembly form your Fordson Major Tractor. If you please let me know |
| Amatt NWOH
05-07-2012 12:57:32
68.20.105.3
Re: Searching for Super Major Block or Parts Tractor in reply to Lamoca4, 05-04-2012 13:01:13
| | Lamoca4, I'd be happy to sell it to you. I haven't looked inside it to see in what condition everything is, so it will be as is. My e-mail is open, send me something and we will figure out the details. Thanks. |
| Amatt NWOH
04-25-2012 13:21:17
68.20.105.3
| I am in Northwest Ohio (about 1.5 hrs south of Detroit/Windsor) and I have a Fordson Major Diesel parts tractor. I will get the serial number for you, but it is a regular Major, about 1955, so I don't know if the block will work with a super major. Maybe I'll get some pics too. |
| monty ratliff
06-09-2012 14:52:18
174.130.122.87
Re: Searching for Super Major Block or Parts Tractor in reply to Amatt NWOH, 04-25-2012 13:21:17
| Quoting Removed, click Modern View to see |
| Amatt NWOH
04-27-2012 12:52:31
68.20.105.3
|   Here is a pic of the serial number tag (1330248) and of the engine. Let me know if you think it might be of use. |
| kborsch
04-15-2012 23:09:41
66.220.99.33
| Farmland tractor wrecking yard in Oregon had a couple supers the last time I checked. |
| Fordson5
04-12-2012 06:39:09
174.251.250.190
| Hey I'm not sure where your located but T and H salvage in Pavo, Ga. has some fordsons in their collection. They may be able to help. 229-859-2643. |
| C Holt
04-12-2012 18:45:28
64.231.119.65
Re: Searching for Super Major Block or Parts Tractor in reply to Fordson5, 04-12-2012 06:39:09
| Thanks. I will keep this place in mind. I'm writing from Ontario so it would be nice to try and locate one closer, if possible. I spoke to my father and he gave me this number as the block number (EIADDN6015). Eventually I may find one. |
| Robert major
04-17-2012 13:05:21
216.130.83.160
Re: Searching for Super Major Block or Parts Tractor in reply to C Holt, 04-12-2012 18:45:28
| Hi Try Teeswater agro parts. It's a wrecking yard in Teeswater Ontario that is at least in your province. it is run by one of the Ireland brothers one had a yard in Moosomin Sask, but haven't dealt with him in a few years. Regards Robert |
| Richard Hare
04-13-2012 20:59:25
199.243.31.158
| | I know it's still a long walk, but Donald Parkinson at British Tractor Wreckers, in Saskatchewan might have a block. (Nearly for sure) Good luck! Richard. |
| C Holt
04-14-2012 16:40:39
64.231.119.65
Re: Searching for Super Major Block or Parts Tractor in reply to Richard Hare, 04-13-2012 20:59:25
| | Thanks, I have looked him up and have sent him an email. If anyone else has any suggestions, the too would be appreciated. |
| 64 Super Major
05-24-2012 22:53:02
24.116.8.149
Re: Searching for Super Major Block or Parts Tractor in reply to C Holt, 04-14-2012 16:40:39
| Can anyone help me get my hand on a 5000 super major three point housing and draft control. I have a Super major with a backhoe attachment. Ot doesn"t have the housing cover required for a three point to be operational. I need everything from lift arms to draft control and housing. I am assuming that all the internal hydrolics are there. If anyony has info they think i could use please let me have it. Thanks |
