Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Fordson Tractors Discussion Forum
Re: diesel in engine oil
Robert major
03-17-2012 15:16:23
Hi on a 52 Major you don"t have to worry about the injection pump seal leaking in to the timing case as it is connected with an external shaft to the motor. it could be the diaphram leaking on the lift pump and eventually it will pull air in the system and quit running. The other common problem is that the injector leak off rail under the valve cover fractures at the joints and lets fuel in the oil pan, To see this you have to take the cover off and run the motor and look for the leak. What ever it is needs sorting now as I have seen many good motors destroyed with diluted oil seizing the cranks. Regards Robert
