Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Fordson Tractors Discussion Forum
Topic: diesel in engine oil
[Return to Forum]
Nic Hohlios
03-17-2012 09:59:54
75.162.100.116
Is it normal to have diesel fuel in the engine oil? I am gaining oil level when I checked the engine oil on my 1952 Major. When I drained the oil I got a little less than 10 qt instruction book state capacity is 8qt's. If not what might be wrong?
[Reply]   [No Email]
Bendee
03-20-2012 16:40:52
58.165.17.170
Re: diesel in engine oil in reply to Nic Hohlios, 03-17-2012 09:59:54
You have the fuel line running under the rocker cover, check for leaks there FIRST. I just repaired one.As GAN and Robert says. surprised if it is not there.
You will note it returns to the fuel tank.
  [Reply]  [No Email]
Nic Hohlios
03-20-2012 17:01:54
75.162.100.116
Re: diesel in engine oil in reply to Bendee, 03-20-2012 16:40:52
Thanks again. We been having snow storms and I have not been able to work on Her. but I have a feeling it the lift pump.
  [Reply]  [No Email]
Nic Hohlios
03-25-2012 20:08:24
75.162.96.173
Re: diesel in engine oil in reply to Nic Hohlios, 03-20-2012 17:01:54
Can anyone tell me were I may get a lift pump Diaphragm Kit? According to the parts manual the part number is E41Z9
  [Reply]  [No Email]
Nic Hohlios
03-17-2012 17:09:20
75.162.100.116
Thanks I didn't think it was right my first diesel,
again thanks
  [Reply]  [No Email]
GAN
03-17-2012 15:19:21
207.204.220.207
Check the return line from the top of the injectors.
  [Reply]  [No Email]
Robert major
03-17-2012 15:16:23
216.130.71.71
Hi on a 52 Major you don"t have to worry about the injection pump seal leaking in to the timing case as it is connected with an external shaft to the motor. it could be the diaphram leaking on the lift pump and eventually it will pull air in the system and quit running. The other common problem is that the injector leak off rail under the valve cover fractures at the joints and lets fuel in the oil pan, To see this you have to take the cover off and run the motor and look for the leak. What ever it is needs sorting now as I have seen many good motors destroyed with diluted oil seizing the cranks.
Regards Robert
  [Reply]  [No Email]
david G
03-17-2012 14:01:33
205.215.206.18
It is not OK, injector pump seal, or lift pump seal is probably bad.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
