Dexta 2000 loader question
Kirk-NJ
I have an early Pre '65 ford 4000 and would like to put the loader that is on the 4000 on a dexta 2000. Any chance it will fit? The ford bracket bolts up to the front axle carrier and I'm not sure if the axle carriers are the same on the dexta. If anybody has photos it might help.
Thanks, Kirk
There will be problems fitting it.
The front connection on the 4000 is fixed, while the bumpers on a Dexta pivot. You cannot bolt to Dexta axle.
The fix for a Dexta would require cutting loader front mount and bolting to the bottom engine to axle bracket just under the engine front balancer.
I put a loader on a Dexta. You'll need Popeye arms to steer it. But, I kept the tires filled to 50PSI and it was very useful.
If you don't want to mount it, let me know and I'll make you an offer.
Wayne
