Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Fordson Tractors Discussion Forum
Re: She stuck i think?
cdmn
01-11-2012 16:34:15
If the starter spins but doesn't turn the engine, it may just be a minor starter problem. The bendix may be dirty and stuck. Does the engine turn if you have the transmission in high gear and you roll the tractor a foot or so? (make sure the shut-off handle is pulled out, so it won't accidentally start and run over something.) If so, remove the starter and check the bendix. Maybe only cleaning it will free it up. Disconnect the battery before you do this, so you don't get sparking. You could also reach in thru the starter hole and pry on the flywheel teeth and see if it is stuck. If it is not actually stuck, you should be able to pull-start the Dexta with another tractor.
