| Fordson Tractors Discussion Forum |
Topic: Re: fordson super major
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Majorman
10-28-2011 00:32:45
81.155.26.136
Majors have vacuum governors so the throttle goes to the manifold. Two pipes come from the manifold to the injection pump governor housing. Inside is a rubber diaphragm.Throttle through the block means it is a tractor between 1952 and 1954. You Super is probably between 1962 and 1964 when they fitted a Simms Minimec pump with a mechanical governor. The throttle rod on these goes straight to the pump. Majors are one of the best starting tractors built, even when badly worn, so I would expect you have a bit of a problem. Not easy to answer without more clues. Have a look at www.fordsontractorpages.nl, you will find a lot of help there. |
[Reply] [No Email] | |
| brian stanek
10-29-2011 18:13:21
207.102.37.246
Re: fordson super major in reply to Majorman, 10-28-2011 00:32:45
| thanks for the info. it seems the tractor with the throttle shaft thru block, has no engine nos stamped on. says super on the grill. also wheels and hood etc are white , with a blue block. quess im kinda confussed. |
| Majorman
10-30-2011 02:32:24
81.155.26.136
Re: fordson super major in reply to brian stanek, 10-29-2011 18:13:21
| | Engine number will be stamped on the flange behind the starter. Someone may have fitted an earlier engine to a Super. Has the tractor got a dash panel under the steering wheel or in front of the gear sticks? Has it got disc brakes? Throttle through the block went out in 1957 on tractors, although I have seen replacement blocks with it, these were for petrol trucks not tractors and are rare. When we fitted new blocks to early tractors, in the dealership, we used a Ford adapter kit that bolted on to the rear of the block and took the linkage around the back as per the later FMD, Power Major and early Super with vacuum governors. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
