fordson oil presure
Anonymous-0
58-60? when wormed up very low oil presure, motor overhaul,rings main &rod bearing, now my oil presure seems to high-80-90,std bearings, what did I do wrong thanks Ken
I would say this is normal. If it has a screw on oil filter, watch to make sure it isn"t expanding. Otherwise, check the viscosity of oil that you are running and try running a thinner oil, especially in the winter. Hope this helps
is there any place for a blockage that could accure during the overhaul, I have the filter element canister (not the spin on) thanks
