| Fordson Tractors Discussion Forum |
Topic: supermajor running away
[Return to Forum]
| Author |
[Modern View]
| vtjoe
08-02-2011 10:34:16
71.161.221.40
this has happened to me before-- while idling, holding up a log with the hoe and cutting firewood chunks, the motor will just start revving up - to max rpm if i don"t move fast enough!! I pull the fuel shut off and restart the motor and everything is good for a while.... then same thing again. It has a Simms Minimec pump with no vacuum governor... so is there a mechanical governor that I need to service and how???? do I need to change the oil? How does it all of a sudden get extra fuel to run so fast? Any help is appreciated. |
[Reply] [No Email] | |
| vtjoe
08-14-2011 04:53:42
64.222.98.67
Re: supermajor running away -followup in reply to vtjoe, 08-02-2011 10:34:16
| here is the latest- I did what was suggested, the air cleaner was fine-- the oil that drained from the pump was a little thin and looks somewhat rusty in color. so new was good. I put in straight 30W and am planning on changing it again soon. I also found an exploded diagram of the pump. very difficult to find as mine has no built in fuel pump or ANY hoses or vacuum governor. just the tach drive sticking out the back and inside throttle lever connection next to the block. diagram shows a rotating centrifugal governor looks like i need to investigate further |
| Bendee
08-07-2011 20:29:48
121.214.93.88
Re: supermajor running away in reply to vtjoe, 08-02-2011 10:34:16
| Minimec..How long since you put oil in the pump? There are two plugs on the lower half. the bottom one is the drain, one immediately above is the oil level. Drain the system and replace the plug. remove the one above. On the top rearward of the injector pipes is the filler plug. put oil in there until it comes out the bottom hole.replace plug and see what that does. |
| Bendee
08-03-2011 23:35:01
121.220.22.62
| Like ShadetreeRet, look for excess air intake first, find it the cheaper option. Clean out the oilbath and fill to oil level.check hoses for cracks etc. |
| ShadetreeRet
08-03-2011 19:46:37
184.2.208.128
| I'm no expert on fuel injection, but I wonder if it could be sucking air somewhere? On many engines excess air will cause one to rev up as well. Interesting problem, good luck. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
