Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Fordson Tractors Discussion Forum
Re: fuel injector pump diaphragm
gregory scott
06-17-2011 06:36:53
Mr. tirestrack you are the greatest!!!
Do i have to remove the iinjector pump from the tractor or can i replace the diaphragm while the injector is still attached to the tractor???
Again THANKS!!!!!!
tiresntracks
06-17-2011 09:51:12
 Re: fuel injector pump diaphragm in reply to gregory scott, 06-17-2011 06:36:53
You're welcome!
You can change the diaphragm while the injector pump is still on the tractor.
gregory scott
06-17-2011 17:05:13
 Re: fuel injector pump diaphragm in reply to tiresntracks, 06-17-2011 09:51:12
my tractor runs great!!!
Thanks TIRESNTRACKS !!!!
can this tractor burn biodiesel?
tiresntracks
06-17-2011 21:21:56
 Re: fuel injector pump diaphragm in reply to gregory scott, 06-17-2011 17:05:13
I'm glad that you fixed the problem.
I don't see what it would hurt to burn biodiesel. The fuel system is pretty basic. I've never used biodiesel myself, but I've been told that you will need a few extra fuel filters when you first start using it and it gels at a lot higher temp. than diesel.
gregory scott
06-18-2011 05:20:05
 Re: fordson dexter an biodiesel in reply to tiresntracks, 06-17-2011 21:21:56
when you say it gels at much higher temp than fosel fuels are you saying that it cant handle lower temp?
tiresntracks
06-18-2011 07:24:05
 Re: fordson dexter an biodiesel in reply to gregory scott, 06-18-2011 05:20:05
Yes. That's what I meant. I don't know the exact temps, but I know it doesn't work well in cold weather, unless you mix it with something else, or use a tank heater. It also varies, depending on what type of oil it was made from.
gregory scott
06-18-2011 08:10:36
 Re: fordson dexter an biodiesel in reply to tiresntracks, 06-18-2011 07:24:05
Thank you sir.
gregory scott
06-17-2011 10:29:21
Sir, i thank u so much.You removed all of my anxiety and fears!
Thank Again!!!!!!
