TractorLinks.com
Fordson Tractors Discussion Forum
Re: fuel injector pump diaphragm
gregory scott
06-16-2011 19:19:59
Are the diaphragms difficult to install in injector pump.
Are special tools needed?
tiresntracks
06-16-2011 22:13:08
 Re: fuel injector pump diaphragm in reply to gregory scott, 06-16-2011 19:19:59
Its not too hard. Remove the vacuum line from the gov. housing to the manifold. Take the 4 bolts out of the housing. The spring will try to push the housing off, so be ready for it. Pull the diaphragm out and remove the washer and cottar pin that hold it on the fuel control rod. Install the new one exactly the same way that the old one came out.
gregory scott
06-17-2011 06:36:53
 Re: fuel injector pump diaphragm in reply to tiresntracks, 06-16-2011 22:13:08
Mr. tirestrack you are the greatest!!!
Do i have to remove the iinjector pump from the tractor or can i replace the diaphragm while the injector is still attached to the tractor???
Again THANKS!!!!!!
tiresntracks
06-17-2011 09:51:12
 Re: fuel injector pump diaphragm in reply to gregory scott, 06-17-2011 06:36:53
You're welcome!
You can change the diaphragm while the injector pump is still on the tractor.
gregory scott
06-17-2011 17:05:13
 Re: fuel injector pump diaphragm in reply to tiresntracks, 06-17-2011 09:51:12
my tractor runs great!!!
Thanks TIRESNTRACKS !!!!
can this tractor burn biodiesel?
tiresntracks
06-17-2011 21:21:56
 Re: fuel injector pump diaphragm in reply to gregory scott, 06-17-2011 17:05:13
I'm glad that you fixed the problem.
I don't see what it would hurt to burn biodiesel. The fuel system is pretty basic. I've never used biodiesel myself, but I've been told that you will need a few extra fuel filters when you first start using it and it gels at a lot higher temp. than diesel.
gregory scott
06-18-2011 05:20:05
 Re: fordson dexter an biodiesel in reply to tiresntracks, 06-17-2011 21:21:56
when you say it gels at much higher temp than fosel fuels are you saying that it cant handle lower temp?
tiresntracks
06-18-2011 07:24:05
 Re: fordson dexter an biodiesel in reply to gregory scott, 06-18-2011 05:20:05
Yes. That's what I meant. I don't know the exact temps, but I know it doesn't work well in cold weather, unless you mix it with something else, or use a tank heater. It also varies, depending on what type of oil it was made from.
gregory scott
06-18-2011 08:10:36
 Re: fordson dexter an biodiesel in reply to tiresntracks, 06-18-2011 07:24:05
Thank you sir.
gregory scott
06-17-2011 10:29:21
Sir, i thank u so much.You removed all of my anxiety and fears!
Thank Again!!!!!!
