mark chapman1
New User
Hi, I have a Fordson Major E1a, approx 1953/4, where with lift/fuel pump attaches to the engine block it constantly leeks at the bottom , I unbolted the two bolts that hold the pump and removed from the engine and found behind the pump there was a metal gasket, which has the two bolt holes there however, there is nothing to fix to the engine block hence it cannot seal and leeks engine oil at the bottom on where the lift/fuel pump is, without this metal gasket there is a big hole, does anybody know what should be behind the lift/fuel pump to seal it. Please Help...... Thanks Mark
