Yesterday's Tractor Co.
Shop Now View Cart
Re: Currect Serial Numbers
Les Fenwick
05-06-2011 17:13:39
Hi Kurt,
The number you posted, 1441843, looks like the engine serial number and I would guess it to be in a Fordson Dexta built in Aug/Sept 1959.
The tractor serial number should run vertically down the front flange of the clutch housing on the left side where it joins the engine.
If the engine and/or clutch housing is original then it might look something like 957E 40123.
There are also date codes on the right side of the 3 main housing, top of the hydraulic cover and back of both axles and behind the injecton pump on the motor.
Kurt Weber
05-06-2011 17:51:27
 Re: Currect Serial Numbers in reply to Les Fenwick, 05-06-2011 17:13:39
Thank you so much Les. This really helps. Take care.
