TractorLinks.com
Fordson Tractors Discussion Forum
Removal of grease nipple.
Bendee
03-04-2011 05:21:08
One of the grease nipples [zerks to some] on the rear axle housing has blocked, it is a press in type,, is there a particular way to remove it or is it just a matter of drilling. any views would be appreciated.
Bendee
03-04-2011 23:00:19
 Re: Removal of grease nipple. in reply to Bendee, 03-04-2011 05:21:08
Thanks people, I'll try those before the 3rd option.
Mike Farmer
03-04-2011 11:29:19
Hi. Is the little internal ball stuck upp or down. If its tight up I have used a very hin nail and a hammer and tapped it free. Then spray some WD40 or the like into the top of the nipple. Most times it will free itself. if its stuck down use a gently heat if that fails the only way I,ve found is to twist it with a pair of grips and replace it. Because if it is down you cant get grease past it.
Incidently where possible I tap the holes a fit screw in type, but thats rare. Luck.
MTF
Mike Farmer
03-04-2011 11:30:31
 Re: Removal of grease nipple. in reply to Mike Farmer, 03-04-2011 11:29:19
It should say a very THIN nail
cj3b_jeep
03-04-2011 11:01:20
I saw a tool at one of the farm shows that you filled with grease and smacked with a hammer and it would clean them out. Heat usually works though.
d beatty
03-04-2011 07:18:39
Have you tried to put some heat on it and put grease gun to it and punp. This will some times open the pluged fitting.
